Weirdness in small items
vincmar
(@vincmar)
Hello, so I have this really strange thing when I print SMALL items, this is just a 4mm cylinder, the bottom always get strangely smaller (the first layer is correct size, then it goes wierd and then it goes normal again, but this happens all the time.
Any sollutions to this? whe I print larger items its barely noticable thoughstrange deformation
Respondido : 22/02/2021 12:55 pm
RE: Weirdness in small items
“...barely noticeable” mmh, that doesn’t sound good. This shouldn’t happen at all. What I see in the picture is a lot of unevenness across the whole length of the cylinder, with small bulges in regula intervals. Plus, there appears to be a significant layer shift right at the beginning. Maybe you want to check the tension on your belts and make sure movements across all axes are smooth
Respondido : 24/02/2021 4:38 pm
