[Resuelto] weird slicer problems
ASCII.encrypt
(@ascii-encrypt)
so ive been remaking an model that was broken and when i go to put it in prusa slicer it says its broken and fills in random parts of it when they are not modeled like that in fusion. to fix this i have to click on the triangle that repairs it then it slices fine
when exported as 3MF however it doesnt fill holes but still says its broken
https://drive.google.com/drive/folders/1MLmTOhnpYcPKa2bw_vzg2O2fz02oskoQ?usp=sharing
google drive link of all files i could think that would be needed
can i get some help and insight for this? i would like to make this public but dont want to give people broken files
Respondido : 07/06/2023 12:19 am
ASCII.encrypt
(@ascii-encrypt)
RE: weird slicer problems
did a stupid mistake in fusion redid the model and now all works well
Respondido : 07/06/2023 1:30 am
Thanks for updating the post, many folk, just let it hang, when they realise an error on their own part...
Would you like to enlighten us as to what the mistake was, so we don't do the same thing?
Respondido : 07/06/2023 10:15 am
ASCII.encrypt
(@ascii-encrypt)
So when I was designing the fins that connect the outer and inner bodies I had extruded 20mm forward then I had extruded and called for a join feature and pulled it 40mm to the rear of the model causing non-manifold verts/edges to appear, I had then revolved that same feature making even more non-manifold verts/edges which made PrusaSlicer really unhappy
Photo below are non-manif verts/edges shown in meshlab
so all in all shortcuts don't always work some times they WILL drive you to confusion
don't be dumb like me  :)
Esta publicación ha sido modificada el hace 3 years 2 veces por ASCII.encrypt
Respondido : 07/06/2023 6:14 pm
ASCII.encrypt
(@ascii-encrypt)
side note: this was the same problem that the original model had which caused issues when trying convert to solid in fusion360 which led me to remodel it!
Respondido : 07/06/2023 6:25 pm
