VASE MODE
Medic57
(@medic57)
VASE MODE
Can anyone tell me how to fix the letter P in vase mode. The letter is used as a diffuser so the middle needs to be there or it's completely open. Will not work.
Attachment removed
Posted : 03/08/2021 2:46 am
Bottom layers should work, top layers will not
You should be able to have bottom layers in vase mode. Top layers won't work with vase mode.
Save your current  3MF project file, zip it up, and attach it to a reply here so we can see your part & settings and give better recommendations.
Posted : 03/08/2021 4:12 am
By definition that cant be printed in vase mode.  You have an outer and an inner perimeter once it gets above the bottom layers.  It would have to print the outer (or inner perimeter) then jump to the other one.  Vase mode is a continuous printing process.  Not a technique that can be used on that shape.
Posted : 03/08/2021 7:24 am
Ringarn67
(@ringarn67)
RE: VASE MODE
Agree with @neophyl
As I understand vase mode a part with more then one perimeter can't be done straight away.
But, if it's just this sign, my guess is a back-lit sign, you're going to make, you can accomplish it by making it as two part and glue them together.
Outer part is made with 4 bottom layer and a little rabbet around the middle hole
Inner part is made with 0 bottom layer and 0,4mm lower
Fits perfectly 😀
If it is a backlit sign you may have to reduce the number of bottom layer, and adjust the design accordingly.
Maybe just 1 layer, and no rabbet in the hole 🤔
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Posted : 03/08/2021 12:06 pm
3 people liked
Medic57
(@medic57)
Vase mode
Exactly what I need. Can you please explain how I can do this? This letter P fits over a letter with LED’s.
Posted : 03/08/2021 12:33 pm
You can always just print with a single wide perimeter
You can always print with a single wide perimeter ("pseudo vase mode"). This works best with a larger nozzle.
Posted : 03/08/2021 12:41 pm
Medic57
(@medic57)
Vase mode
Posted : 03/08/2021 2:11 pm
Medic57
(@medic57)
Vase mode
With letter
Posted : 03/08/2021 2:12 pm
Ringarn67
(@ringarn67)
Posted by: @bobstro
That is WAY easier then how I did it 🤣
Anyway, I attach my f3d-file if someone is interested.
Look at "Change Parameters", there are some explanations in there, also I named the bodies and sketches to something useful.
I know it is possible to do all of it in one sketch, but it was easier for me to explain if I use more than one.
Attachment removed
Posted : 03/08/2021 2:18 pm
Tips for diffusion panels
Back before the "glass" discussion devolved, there were several techniques being discussed for diffusion or "clear-ish" panes. You might want to look at that if you're looking for more consistent clear panels.
Posted : 03/08/2021 2:35 pm
Medic57
(@medic57)
Vase mode
Worked perfectly!!!!
Posted : 03/08/2021 9:47 pm
