Variable layer smoothing for macOS trackpad
Garth Snyder
(@garth-snyder)
I've been playing with variable layers in 2.1, and I'm really very impressed! It's easy to use and seems to give very good results.
One thing I haven't been able to figure out: how do you access the "smooth the layer height" operation with a trackpad on macOS? The popup instructions assume you're using a mouse, but all the other ops seem to map pretty directly to the trackpad.
Shift-RightMouse is supposed to do smoothing, but that works the same as RightMouse drag (that is, two-finger drag on the trackpad) for me (it grows or shrinks the adjustment window).
For anyone else with a trackpad, here's how things are working on my system: Two-finger drag grows or shrinks the adjustment window. Three-finger drag adds detail. Shift-three-finger drag removes detail; if you want to coarsen beyond the nominal layer height for the print, use Control-three-finger drag.
Respondido : 13/10/2019 10:54 pm
