Using PrusaSlicer as a batch-conversion software (STL to 3MF)
Stemfie3D
(@stemfie3d)
Hi! 🙂
I am unsure where to post a feature suggestion for future versions of PrusaSlicer, so I am giving it a go here. If you know of a more official or direct way to suggest this feature to the developers of PrusaSlicer, please let me know.
I am looking for a tool to batch-convert STL files to 3MF. Simply put, this tool would convert each STL file into a folder (and sub-folders) and create a 3MF version of the STL files in the same path or other if specified.
I thought that PrusaSlicer could be the perfect software for this task. As it also has a feature for simplifying models to reduce the file size, this could be added to the batch-conversion task. This tool could easily be placed under the File menu as File > Batch-convert.
I am thankful for any information you may have regarding this request to batch-convert STL to 3MF. I found the software Spin 3D and gave it a try, but it turned out that the resulting 3MF files became unreadable by PrusaSlicer and other 3MF-compatible software.
Cheers, 🙂
Paulo
Publié : 03/08/2022 9:05 pm
RE: Using PrusaSlicer as a batch-conversion software (STL to 3MF)
Sure. It's https://github.com/prusa3d/PrusaSlicer
Publié : 04/08/2022 8:22 pm
Try PrusaSlicer command line options
Posted by: @stemfie3d
[...] I am looking for a tool to batch-convert STL files to 3MF. Simply put, this tool would convert each STL file into a folder (and sub-folders) and create a 3MF version of the STL files in the same path or other if specified.
I don't have a definitive answer for you, but a possible starting point. PrusaSlicer was based on Slic3r which had a rather complete command line feature set that I made frequent use of in the past. After the transition and rewriting of PrusaSlicer, some features were changed or lost. It does appear that the --export-3mf option still exists. I can't do any more testing right now, but definitely check this option out. On MacOS the option is still present in PrusaSlicer 2.4.2.
What you'd need to do is to write a script to load each STL into PrusaSlicer, then export as a 3MF. You'd probably want to tweak the settings for each file to use your preferred print settings.
Publié : 04/08/2022 9:17 pm
Stemfie3D
(@stemfie3d)
Thank you both for the suitable answers! I'll look into this shortly. 🙂
Cheers,
Paulo
Publié : 05/08/2022 6:41 am
