        Update to PrusaSlicer 2.7.2 broke PrusaLink
I was successfully sending gcode to my XL via PrusaLink. I updated to 2.7.2 final and changed nothing else, and it no longer works, I get this error message:
PrusaSlicer has encountered an error
Upload has failed. There is no suitable storage found at <hostname>.
Couldn't connect to server:
Failed to connect to <hostname> port 80 after 1 ms: Couldn't connect to server
[Error 7]
Also the "Test" button in Printer Settings > Gear Icon shows the same error message, starting at the "Couldn't connect to server:" part.
When I do a quick test in Terminal with curl using that same hostname, I can connect and I get a response:
% curl -i --compressed <same hostname> HTTP/1.1 200 OK Content-Type: text/html; charset=utf-8 Connection: keep-alive Content-Length: 7211 ETag: "2616275659" Content-Encoding: gzip <!doctype html><html><head><meta ch[...]
Has anybody else started seeing this after the latest update?
                            Veröffentlicht : 05/03/2024 6:26 am
