Understanding what happens between objects during sequential printing..?
My extruder (Ender3 Max unmodified) has the fan plastic as the lowest part. The distance from the bed when the nozzle touches the bed is ~3,3mm.
I am printing small objects with a height of 1mm. Does this mean I can set the "Extruder clearance radius" to a very small value similar to non-sequential printing (6mm) ??
What happens when one object is finished? How high will the nozzle be raised? Which path will it take to the next object? Will it travel only between objects, where their red clearence ovals are touching? Or what route will it take? I tried to display the tool path in Prusa slicer, but it doesn't show. It jumps directly from one object to the next without animating the nozzle between them.
Thanks for your help!
Publié : 08/12/2024 3:34 pm
