Turn off the first raft layer under supports?
BelowAboveAverage
(@belowaboveaverage)
Is it possible to disable the first raft-like layer under supports?
Getting it off my print bed sucks.
Publié : 15/04/2020 9:06 pm
1 personnes ont aimé
RE: Turn off the first raft layer under supports?
No.  It is not possible to remove it with the current versions of Prusa Slicer (as of 2.2.0).
Publié : 15/04/2020 10:11 pm
vintagepc
(@vintagepc)
Membre
also, doing so results in a much greater risk of support failure.
Publié : 16/04/2020 4:23 pm
BelowAboveAverage
I get that, but on my textured print bed, PETG sticks so well that I usually don't have problems with supports, and the single layer is sometimes hard to remove. If it was thicker, I could peel it off more cleanly.
Publié : 16/04/2020 4:36 pm
Bendermk6
(@bendermk6)
You can use a brim, maybe it helps a bit to remove the firstlayer support.
Second option is a min. 3 layer raft, so the firstlayer is a bit "denser".
Or you can just add a generic part and make it 0.2mm height, place it under the support and you have one "full" layer under the support.
Publié : 19/04/2020 5:53 am
Bendermk6
(@bendermk6)
I just had a better idea 😀
You can just add a 0.2mm height layer around your object directly in your CAD.
Attachment removed
Publié : 19/04/2020 6:10 am
BelowAboveAverage
Fantastic suggestions. I appreciate your time. Thank you.
Publié : 19/04/2020 2:37 pm
I keep two files on my laptop, Mouse ear and Mouse Strap...
Mouse ear is a disc 0.2mm thick and 20mm diameter, Mouse Strap is 0.2 thick, 20mm long 2mm wide, they have various uses... please see the attached file, which includes a document with pictures and the files
below is a sample of using the mouse ear, under supports...
Attachment removed
Publié : 19/04/2020 3:16 pm
Joan I too used to keep a mouse ear file handy but no longer. You can now add the basic primitive shapes directly from Slicer. Once you unlock the scaling you can then make them 1 layer thick and whatever size you want.
Publié : 19/04/2020 3:30 pm
