Trying to cut an object, I get an error "Object outside the print area..."
allanonmage
(@allanonmage)
I have used the cut tool before, but only once, and a long time ago (probably a different version too).  I scaled some parts up, and cut off the top and in my case, it works.  I'd like to do that with another of the parts, and since we don't have a part specific ruler anywhere in-program, I'm using the previous scaled up part as an indicator of where I need to cut the new piece.  However, when I draw a line with the tool, I get an error and no cut.  I might be doing it wrong, but there's really not much to screw up here, so idk what's going on.
I've done an internet search, found the how to guide, checked the bug tracker, and haven't found anything to help.
This(link) is the thing I'm working on:    I've printed the base and 2 sides at 150%.  The sides were cut with prusaslicer, and now I'm trying to do the same with the back.
Here's the error message.  Not much to go off of.
Version 2.7.1+win64
thingiverse.com/allanonmage
Postato : 22/12/2024 1:42 am
allanonmage
(@allanonmage)
RE: Trying to cut an object, I get an error "Object outside the print area..."
I can't seem to edit to add this to the post above, but this is what I'm doing when I overlap them to make the cut, and the subsequent error message.
Postato : 22/12/2024 1:49 am
Don't forget that you have the measuring tool to help you with this sort of work.
The 'error' is something between a warning and a true error, if any part still overhangs the printable area after the cut it will remain - but a rearrangement or a second cut should fix it.  Sections moved wholly off the plate to make room (and perhaps onto another plate) will not interfere with slicing.
If the cut is not performed you may have one or more parts unselected.
Cheerio
Postato : 22/12/2024 1:40 pm
allanonmage
(@allanonmage)
Never heard of the measuring tool, that would be helpful.
I managed to get it to work by changing the cut tool to "cut into objects" while they were occupying the same bed space, then it was able to jetison the extra object off the bed and be happy.
Why does the cutting tool want to rotate the part?  That makes no sense either.
Postato : 22/12/2024 1:43 pm
The measure tool is in your old version 2.7.1.  It was added in version 2.6 Located on the left along with the other tools such as Scale, Move etc.
Perhaps reviewing the Prusa Slicer knowledge base for the basics might help https://help.prusa3d.com/article/ui-overview_1766   (although as you are using an older version there will be more options covered in the KB).  The measure tool specific page is https://help.prusa3d.com/article/measurement-tool_399451
You might also want to look at the new versions with the latest Cut tool as its had a few upgrades.
Postato : 22/12/2024 1:58 pm
