Tried to extrude 5mm before print start but prusaslicer put M104 and not M109
marcottt
(@marcottt)
Hi all. i tried to prime 5mm of material putting a command G1 F200 E15   in "printer option" -> starting gcode  but prusaslicer start this gcode before nozzle get temperature so i get a cold extrusion.
There is some way to prime material after nozzle reach temp but before start print without edit each time gcode ?
attached an image.... you can see (A) prusaslicer start temp but with M104 so maybe still cold nozzle, after prime 5mm after start and M109 and wait for temp.
Thanks for help.
Best Answer by bobstro:
I've got some notes here on the procedure for customizing startup gcode. You can adapt what I've documented to do what you want. Line 53 is essentially doing what you have described, pushing filament before starting the prime line.
Respondido : 25/03/2020 5:44 pm
JuJu
 JuJu
(@juju-2)
RE: Tried to extrude 5mm before print start but prusaslicer put M104 and not M109
In the Printer Settings tab, Custom G-Code, Start G-Code window, you can add it in there, after the Temperature settings....
Respondido : 25/03/2020 6:46 pm
Respondido : 25/03/2020 7:09 pm
1 les gusta
marcottt
(@marcottt)
Posted by: @jmstone
how to put after ? this is what i have made but these command are send before temp manage, what you mean with "after the temperature settings" ?
Respondido : 26/03/2020 8:10 am
marcottt
(@marcottt)
@bobstro
Hi and thanks for yout support. i think to use the
M109 S[first_layer_temperature] ; wait for extruder final temp
command before the prime command to reach nozzle temp. there is somewhere a comprensive listo of the variable usable ?
ithink to make some other nice thing but i don't know which variable are usable, like [first_layer_temperature]
thanks again
Respondido : 26/03/2020 8:18 am
JuJu
 JuJu
(@juju-2)
You don't say what Printer your using, whether its a Prusa Mk2\3 or a custom printer e.g. DBot coreXY ?, but for my MK2s, with the latest PrusaSlicer 2.2.0, my start code is:
M115 U3.2.3 ; tell printer latest fw version
M83 ; extruder relative mode
M204 S[machine_max_acceleration_extruding] T[machine_max_acceleration_retracting] ; MK2 firmware only supports the old M204 format
M104 S[first_layer_temperature] ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] ; wait for extruder temp
G80 ; mesh bed leveling
G1 Y-3.0 F1000.0 ; go outside print area
G92 E0.0
G92 E0.0
So to extrude 5mm you will need to add a line between the M109 line and the G28 line (see below), but I'd also add a command,to ensure the nozzle was at least 10mm off the bed:
G1 E15 F200 ;  EXTRUDE some material
Respondido : 26/03/2020 9:58 am
