Transfering profiles from Window to Linux
tcoulon
(@tcoulon)
Hi. I'm usually using PrusaSlicer (Linux version  2.71, AppImage) for my Prusa i3. Now I 'm testing a new Artillery X3 Pro, and Artillery provides a slicer... that actually is PrusaSlicer, in a Windows Version, and with profiles for the new Artillery  Printers.
I have copied the Artillery directory and the Artillery.idx and Artillery.ini files to ./config/PrusaSlicer/cache. But I still don't see the Artillery printers as I do in the Windows version. Is there something more I should do? I can, of course, start the Windows computer to slice for the X3, but it would be nicer on Linux.
Postato : 07/01/2024 8:09 pm
Zac E.
(@zac-e)
Utenti
RE: Transfering profiles from Window to Linux
Hey there, I created an account and started looking for a solution for a similar issue I was having with my Anycubic Kobra 2 Max until I got tired of looking and had a 3 month long troubleshooting fun fest. Turns out the easiest answer is the best.
if you "Import Config Bundle..." your Artillery.ini file it should dump every printer config in there.
Postato : 13/07/2024 12:55 am
