(Too) wide bottom support interface layers on dual extruders using soluble material
Page 2 / 2
Dave
 Dave
(@dave-12)
RE: (Too) wide bottom support interface layers on dual extruders using soluble material
@elphil I just realised properly here that you're using soluble material for the interface layers. While you're waiting for a solution (aha) for getting the slicer to do what you hope for,  you could design-in bodies in your CAD package for the locations of the interface layers, set those to the soluble material extruder, and switch off interface layers in the slicer.
Posted : 02/04/2024 10:23 pm
elphil
(@elphil)
Hi Joan, hi Dave,
thanks for your replies! When first slicing, dual extruders and water soluble filaments were selected, and I was able to print the part halfway decently, just the interfaces were sagging. (Yesterday, I did not set the dual extruder Printer setting, but it does not seem to affact the support generation).
@Joan: I did play around with organic support before, but hat a similar problem, the interfaces made from soluble material were protuding from the layers below them. I tried again now using 'tip diameter' = 1 mm 'branch diameter' = 3 mm, 'branch distance' = 0 and 'branch density' = 100% and that looks better in the slicer, but there's still support material printed in the air. Will try to play around some more to get a decent interface layer and then try printing.
@Dave: That is also a great idea, will try that too, that should solve the problem if I get it implemented, great!
Thanks again for all the help,
Cheers
Philipp
Posted : 03/04/2024 9:44 am
Page 2 / 2
