Supports where there was none before?
DragonDon
(@dragondon)
I recently switched from Cura to PrusaSlicer to further develop my 3D skills.  I then printed a part that was previously donjon Cura and for some reason, PS added income supports to an area that didn't;t have any before.  I thought it was kinda odd as the previous prints turned out fine.  Wait, they aren't 'supports, not sure what the correct term is but they go horizontal across a hole.  They are light enough to simply punch through/cut out but I'd ike to know where would I look to be able to stop this from happening on an area that seemingly doesn't need it in Cura but Prusa adds it in.
Opublikowany : 12/01/2022 8:01 pm
DragonDon
(@dragondon)
RE: Supports where there was none before?
Correction, I just checked.....PS filled in a hole.  What an odd behaviour.
Cura-sliced bracket: https://imgur.com/t4ZKRnE
Prusa-sliced Bracket: https://imgur.com/ckQmzfM
Opublikowany : 12/01/2022 8:11 pm
DragonDon
(@dragondon)
Seems I'm answering my own questions as I go.  I tried the 'simplify model' option, sliced and the hole is no longer covered.
If the Prusa team reads this, may I suggest NOT using a DARK BLUE to represent lines covering an opening on a DARK GREY platter by default.  I didn't even notice the whole being covered up.
Opublikowany : 12/01/2022 8:17 pm
sylviatrilling
(@sylviatrilling)
Please ZIP your .3mf file and attach to a post. (It must be ZIPPED or the forum won't attach it.)
Mk3S+,SL1S
Opublikowany : 12/01/2022 9:00 pm
Marvin
(@marvin)
Sounds like a broken model. Are there any errors reported in the info box in the slicer?
Opublikowany : 13/01/2022 9:42 am
