Supports on the build plate should have a solid bottom interface for better adhesion
gcode
(@gcode)
Is there a solution to this problem? For instance, does anyone know of a gcode workaround I can use?
For reference I would like to rid this problem, described here: https://github.com/prusa3d/PrusaSlicer/issues/1165
If this has already been discussed and I failed to find it through endless searching, please point me to the correct link. TIA
Publié : 21/12/2019 9:40 am
RE: Supports on the build plate should have a solid bottom interface for better adhesion
I can only tell you that the default dense interface layers work very well provided your print surface is properly cleaned and Live-Z calibrated. You can adjust the density of the support layers.
Zip and upload your STL or (better) 3MF project file for more suggestions.
Publié : 21/12/2019 4:05 pm
Edit: My memory was bad. The interface layer density is only for the bits directly supporting the part. I may have been thinking of Cura.
It's a reasonable feature to implement, but you should be able to get decent adhesion in the meantime.
Does creating a modifier block help? It won't be tailored to your part, but you can get a solid layer under key bits of support. I've used this approach for creating mouse ears to tack down sharp corners.
Publié : 21/12/2019 4:57 pm
gcode
(@gcode)
Thank you for the suggestion. Creating a modifier block is brilliant, but cumbersome and laborious on complex geometry (although it may work on simple designs - idk, haven't tried it yet). I'll give it a go today and see what I can do. Thank  you again for your creative suggestion.
Publié : 21/12/2019 6:53 pm
