Supports NOT whereI need it!
Ossy HH
(@ossy-hh)
G'day printers! OK, this is the first issue I've encountered-  I have an object that the large flat area is elevated, I add Supports, it shows covering entire under side surface, when I Slice- it leaves bottom unsupported and only puts Supports on the perimeter! the entire flat underside is unsupported- cannot figure out why please help!
Postato : 24/11/2021 7:20 pm
jkavalik
(@jkavalik)
Utenti
RE: Supports NOT whereI need it!
Check Print Settings->Support Material->Don't support bridges
Postato : 24/11/2021 7:26 pm
Swiss_Cheese
(@swiss_cheese)
@jkavalik means, un-tick the setting "Don't support Bridges" .
Good Luck,
Swiss_Cheese
The Filament Whisperer
Postato : 25/11/2021 3:51 am
Ossy HH
(@ossy-hh)
Awesome it worked thanks!!
Postato : 25/11/2021 8:54 pm
