support prusa slicer
moi
 moi
(@moi)
bonjour tous le monde
merci de m avoir accepter dans votre groupe
je sollicite votre aide car j utilise prusa slicer comme logiciel
et j ais des soucis pour retirer les supports
avez des reglages a me conseiller
merci d avance
si joint la photo de mes reglages support
Hello everyone
thank you for accepting me in your group
I request your help because I use Prusa Slicer as software
and I have trouble removing the supports
have settings to advise me
thank you in advance
if attached the photo of my settings support
Opublikowany : 25/08/2019 10:03 pm
RE: support prusa slicer
I cant see your settings as your image is too small.  The image settings on the forum are very bad, you need to link to the media usually which isnt the default.
Anyway I have found that the default contact z setting of 0.1 is too small and does make supports difficult to remove.  I usually set mine to 0.2mm and I think Bob sets his to 0.25.  Located in Print Settings >Support Settings > Contact Z Distance
Opublikowany : 26/08/2019 8:05 am
moi
 moi
(@moi)
Opublikowany : 26/08/2019 10:12 am
moi
 moi
(@moi)
merci pour ta reponse j ais remodifier la photo
