Support material on a spiral
AlexB
(@alexb-2)
I have a spiral that I'm trying to print and it needs support, of course. I tried to manaully add supports, but couldn't make it work. With auto supports, it adds suport from the build plate to each level of the spiral (see below). I'm thinking it only needs support for the first full 360 degree are and then each other "level" would be supported by the lower ones. Is there an option for that?
Best Answer by JoanTabb:
Have you tried 'Snug' supports?
Or if you load the latest slicer 2.6.0 Alpha 6. you could try 'Organic' Supports
Opublikowany : 05/05/2023 5:34 pm
RE: Support material on a spiral
Opublikowany : 05/05/2023 7:47 pm
1 ludzie polubili
AlexB
(@alexb-2)
Thank you so much. Snug was what I was looking for but I like the Organinc one too. Thanks again.
Opublikowany : 05/05/2023 8:16 pm
