Support in ONLY certain Areas?
I am making a USB Hub holder. It's the shape of a rectangular frame, with "slots" in the side, where the USB hub, slides in at an angle. There is an purposeful opening above and below the USB for airflow. The entire hub holder, and hub will sit under a guitar pedalboard. (see www.pedaltrain.com if you don't know what that is)
CHALLENGE: I understand the need for supporting a rectangular frame with an opening in the center (see the pics).... however..... if I check support (which is more of a yes/no thing); then I get support filament in the slots as well - and it's WAY TOO difficult to cut or remove from the slots.
Is there a way to indicate "where" to have, and "where NOT" to have support?
Thanks!!
AJ
Publié : 20/01/2025 2:03 am
