Suggested improvements for PS 2.2
Mauricio Moraes
(@mauricio-moraes)
Prusa Slicer is by far, one of the best slicers available out there. However, there are few things that would be nice to have or be able to do:
1- Line preview: PS has a scroll bar that only allows layer by layer preview, but sometimes, it is important to see where the line starts and ends.
2- First layer speed should be moved to the filament settings. Different types of filaments require different first layer speeds
3- Ability to modify / save system presets without the need of saving a new one. I understand this is a little trick because the preset is overwritten every time there is a preset update but the  question "Do you want to update it" is already there and the user has to choose to make the change.
4. Ability to delete added / unused printer presets
5- Addition of a Total number of layers that can be added in the layer change gcode.
This topic was modified 6 years temu 3 times by Mauricio Moraes
Opublikowany : 12/12/2019 7:55 pm
RE: Suggested improvements for PS 2.2
This is a peer to peer forum,its pretty rare for the devs to post here.  If you really want to make suggestions post over on prusa slicers Github page https://github.com/prusa3d/PrusaSlicer/issues
Put each of your suggestions into a separate issue.  That way they can all be tracked and considered individually by the system/devs.  You have a far higher chance of getting traction that way.
You will also find that several of those suggestions are already on the system and have been for some time.
Opublikowany : 13/12/2019 8:20 am
Doug
 Doug
(@doug-6)
@neophyl
Unfortunately when i go to that site it requires a device verification code that is supposed to be sent by email, no email is ever received, as such no ability to comment. options????
Opublikowany : 14/12/2019 11:30 pm
