Start z raised
Hello. I am printing in two colors one at a time. When I print the second one, the nozzle hits what has already been printed. Could someone help me solve this problem. Thank you so much
RE: Start z raised
could you please save a project file from Prusa Slicer, then ZIP Compress the project file, and attach the zip file to your next post,
Otherwise we are just guessing what you are trying to do
Thanks for answering. I'll give you this example so you can see if the same thing happens to you.What I do is make object 2 negative and from there I get gcode 1. Then I do the opposite and get gcode 2. So I print it. 1 goes first and when it finishes I print 2. I have gcode commands to be able to make these color changes. The z-jump does fine once I start printing but not when it starts.
RE: Start z raised
I Guess that's a flat NO!
