Start position modify
Pretty new to this but Prusaslicer has given me the best results.
  One issue I’d love to fix is whenever I start a new print, the temp drops to 150, my printer does an auto-level, and then it sits in the center of the bed until it comes up to heat. By the time it’s ready to print, there’s a blob that I can’t always get to and it ruins the bottom (or face) of my parts.
Which printer is this?
Which preset are you using?
RE: Start position modify
Sorry, forgot to include that...
I'm running a CR-10s PRo V2. The print profile is a slightly modified .2mm profile.
CR-10s PRo V2 users?
Calling CR-10s PRo V2 users, this one is outside my experience but I suspect a homing call is being missed or is misplaced in the startup code.
I've been printing some test parts to dial in my first layer and noticed that if i turn off auto-level, it starts at the corner of the bed. But with bed level on, it drools right in the center.
As Diem posted, it's probably in the custom gcode. Suggest you post what you are using.
BTW Non-Prusa profiles are user supplied.
