Start position modify
Agewon
(@agewon)
Pretty new to this but Prusaslicer has given me the best results.
  One issue I’d love to fix is whenever I start a new print, the temp drops to 150, my printer does an auto-level, and then it sits in the center of the bed until it comes up to heat. By the time it’s ready to print, there’s a blob that I can’t always get to and it ruins the bottom (or face) of my parts.
Opublikowany : 25/10/2022 2:02 am
Which printer is this?
Which preset are you using?
Opublikowany : 25/10/2022 2:32 am
Agewon
(@agewon)
RE: Start position modify
Sorry, forgot to include that...
I'm running a CR-10s PRo V2. The print profile is a slightly modified .2mm profile.
Opublikowany : 25/10/2022 11:44 pm
CR-10s PRo V2 users?
Calling CR-10s PRo V2 users, this one is outside my experience but I suspect a homing call is being missed or is misplaced in the startup code.
Opublikowany : 26/10/2022 1:17 am
Agewon
(@agewon)
I've been printing some test parts to dial in my first layer and noticed that if i turn off auto-level, it starts at the corner of the bed. But with bed level on, it drools right in the center.
Opublikowany : 26/10/2022 3:17 am
towlerg
(@towlerg)
As Diem posted, it's probably in the custom gcode. Suggest you post what you are using.
BTW Non-Prusa profiles are user supplied.
Opublikowany : 26/10/2022 2:27 pm
