Some of the Updates Failed to Install Properly - PrusaSlicer 2.5.2
msprague
(@msprague)
This happens to me every single time I open the slicer.  Opening "as administrator" on Windows 11.  It will prompt me that something needs to be updated or repaired, appears to run through the process successfully then throws this error at me.  Every time.  Any thoughts on what  I might need to do or am doing wrong? Don't be confused by the image, it was happening pre-2.5.2, same issue, same behaviour.
Opublikowany : 18/06/2023 8:16 pm
Hello
(@hello)
RE: Some of the Updates Failed to Install Properly - PrusaSlicer 2.5.2
If you re run the installer and chose repair that should fix it
Opublikowany : 18/06/2023 10:07 pm
msprague
(@msprague)
Thanks, I've done that a couple of times with the same result. I noticed launching without admin access will bring it up without any issues but for updates it needs admin access.
Opublikowany : 18/06/2023 10:24 pm
Hello
(@hello)
that does seem strange maybe the file isint fully there
Opublikowany : 19/06/2023 12:23 am
msprague
(@msprague)
I'll try downloading the update and give it a go.
Opublikowany : 19/06/2023 2:09 am
