Smooth variable layer height on 2.1.1
towlerg
(@towlerg)
Very new to everything 3d but while having a play with 2.1.1 of Prusaslicer. Could somebody explain what shift right mouse button (smoothing) does? I think I understand what variable layer height is, what it's for and the other functions but shift right mouse button doesn't seem to do anything.
Napsal : 31/12/2019 4:11 pm
Mimir
(@mimir)
RE: Smooth variable layer height on 2.1.1
The variable layer height function is a marvelous tool when it functions.
Working on a Mac (no mouse) I have the same questioning when making crlt-click, which should be the equivalent of your right-click on a PC.
Napsal : 01/01/2020 10:06 am
Mimir
(@mimir)
It seems to be the case, that at least the Mac version of PrusaSlicer 2.1.1. which should be the last update, you actually don't find the "Adaptive Slicing tap : Printsetting/Layers and Perimeters/Use Adaptive Slicing and neither just like the tap: Adaptive Quality. The "Use Adaptive Slicing" tap should be ticked for the variable layer height to become active.
See here: https://manual.slic3r.org/expert-mode/variable-layer-height
Napsal : 04/01/2020 7:35 am
Mimir
(@mimir)
Go here: https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-2-2-0-alpha2-adaptive-variable-layer-height-feature-better-than-expected/
Napsal : 04/01/2020 7:45 am
