Slicing profile for the test prints?
ads_will
(@ads_will)
Utenti
Hello, I dont know why but the test benchy rules which is the default test file on the core one only takes 14 minutes, but on prusaslicer when I choose .28mm draft it ends up being 25 minutes. No matter what settings I change (e.g speeds, acceleration) nothing changes maybe it goes from 25 minutes to 23. Can anyone help me find the profile they use because even on the other test prints they are like 1 hour faster.
Postato : 02/10/2025 3:58 pm
That file is not a standard test; it's more of a party trick. The settings will be of no use to you, they are optimised for that single print and will probably fail for almost anything else.
For the standard test benchy download the file from https://www.3dbenchy.com/
Postato : 04/10/2025 2:08 am
1 persone hanno apprezzato
ads_will
(@ads_will)
Utenti
RE: Slicing profile for the test prints?
That would make sense for like the benchy and so but even like the other test prints are noticably much faster in movement then compared to like 0.28 draft
Postato : 04/10/2025 5:12 am
If the files are standard gcode produced by PS then the settings are all stored at the end of the gcode.  You can either manually look through them to get an idea of what was set or you can simply use File>Import>Import Config from the PS menu and select the gcode file.
Postato : 05/10/2025 4:04 pm
