Slicing: Gap in narrow cone when slicing temperature tower
Hello!
I want to print a temperature tower, but I've got a problem with small cones that are integrated into the tower. There seem to be "floating" pieces at the top of the cones:
Is there a way to prevent these gaps?
I'm using the PrusaSlicer version 2.5.0 on Windows 64-bit.
Thank you in advance!
I've attached the project file with the tower and the problem as a ZIP file: SmartTemperatureTower_Stand 220-185.zip
Best Answer by Neophyl:
Change the slicing engine from Arachne back to Classic. The current default arachne settings have problems with some models including this one.
Print Settings>Layers & Perimeters>Advanced>Perimeter Generator. Its a yellow setting so you must be in Advanced/Expert mode to see it.
RE: Slicing: Gap in narrow cone when slicing temperature tower
That fixed the problem. Thank you very much!
