Slicing for MMU3 not respecting multimaterial painting designations
Edelberg Designs
(@edelberg-designs)
Membre
Hi All!
The .3mf file for this question can be downloaded from Google Drive.
I am setting up a multimaterial print, and I have used the Prusa Slicer multimaterial painting tool to apply my desired colors to the model (see first image). When I slice this design, the desired white background is assigned to green (see second image). NB, the bottom of the print (i.e. first layer) should be green.
My first guess was that this was something to do with the number of layers in the base plate, but there are 6 layers before the surface that is supposed to be white, plenty for a transition from green (the underside) to white.
What really confuses me is that when I attempt to fill the background with a different color (see third image), the slicer seems to respect the desired color (see fourth image).
Finally, if I try coloring the part that should be white with a color that is not present anywhere else in my design (violet), the painted color is, once again, not respected (see images five and six).
So this makes me think that there is something about having contiguous colors (like the orange and black) that helps the slicer respect the requested color? Honestly, I am quite puzzled. Any help or ideas you might have would be greatly appreciated.
Ce sujet a été modifié il y a 2 years par Edelberg Designs
Publié : 15/08/2024 7:14 pm
BaconFase
(@baconfase)
RE: Slicing for MMU3 not respecting multimaterial painting designations
At first I thought there was something wonky with the stl since it seemed like the surface thats giving you issues seems to take its color for the bottom surface, ie if I color the bottom of the stl white then the top surface you want as white also becomes white.
Then I tried different colors and it got super weird.
If the bottom is black then the top is white, but then you get the top perimeters on the bottom too:
The other colors don't do that, but they also color the top surface whatever the bottom is:
Then tried what you showed and colored the top orange (with a green bottom) and now the orange top perimeters are showin on bottom:
And playing with the new single perimeter parameters didn't seem to affect anything.
So I'm thinking its PS being buggy. Seems like something worth posting on the Github to get dev eyes on imo
Publié : 15/08/2024 10:12 pm
1 personnes ont aimé
Edelberg Designs
(@edelberg-designs)
Membre
@BaconFase, thanks for the suggestion. I have reported the bug here: https://github.com/prusa3d/PrusaSlicer/issues/13252
Publié : 16/08/2024 1:28 am
