Slicer won't let me use M600
I'm using an 5T Prusa XL but have a print that requires 9 colors so I need to use the M600 command to change colors on layer. The first handful of layers are multi color and require 4 of my colors. After the those first few layers, the remainder of the print only requires changing out the color for the layer. But the slicer is saying that M600 won't be used until the end of the print. How do I go about using the M600 command and swapping out my colors on layer change?
Opublikowany : 12/12/2024 3:04 pm
RE: Slicer won't let me use M600
Did you ever figure this out?
Opublikowany : 01/02/2026 8:40 pm
