Slicer support issues
Medic57
(@medic57)
OK so I changed my support settings to the recommendations of some users. But When I print now the files are failing. Any help?
0.25 mm z distance
75% xy distance
3mm support spacing
4 Interface layers
0.2 mm Interface layer spacing.
Veröffentlicht : 31/07/2021 4:19 pm
I see the rough undersides. Exactly how are they failing? Are parts coming detached mid-print, or just coming out poorly? Save your current  3MF project file, zip it up, and attach it to a reply here so we can see your part & settings and give better recommendations.
Veröffentlicht : 31/07/2021 6:04 pm
Medic57
(@medic57)
Thanks for replying. I am on a Mac, so not sure how to zip my settings. They are just coming out poorly at the end. If I stick to the stock settings they look good except when I try to get the supports off it leaves unwanted filament on the part that just won't come off. As you can see very rough edges wherever the supports attach.
Veröffentlicht : 31/07/2021 8:58 pm
Medic57
(@medic57)
Also the ends of the axle are supposed to be round.
Veröffentlicht : 31/07/2021 9:00 pm
Right-click->Compress
On Mac, just right-click on the file and choose compress. That should create a .zip archive that you can attach to a reply.
Veröffentlicht : 31/07/2021 9:02 pm
Medic57
(@medic57)
Rear Frame_0.15mm_PLA_MK3S_3h44m.gcode
Veröffentlicht : 31/07/2021 9:49 pm
Do a File->Save project to create a 3MF project file. Zip that up and attach it to a reply. We can pull setting out of a gcode file but there's still a lot of info that can only be seen in the 3MF project file.
Veröffentlicht : 31/07/2021 11:24 pm
Medic57
(@medic57)
Front Frame.3mf
Veröffentlicht : 01/08/2021 2:55 pm
