slicer removes a section of the model!
phil
 phil
(@phil-8)
This is very wierd... slicer seems to take a slice out of my model! no idea why or how. If I orient the model differently, then a different slice is missing!!! any ideas whats going on? I'm using 2.4.2
Publié : 31/05/2022 11:57 am
Robin
(@robin)
RE: slicer removes a section of the model!
Difficult to tell without the project file. If you save and zip your slicer project, you can attache it to your post for everybody to see and inspect...
Publié : 31/05/2022 2:09 pm
Please go to Prusaprinter's File menu and save your project as a 3mf file. Zip it and attach it to a post here. You have to use your operating system's compression tool to create a zip file or the forum software won't allow it. The 3mf file will contain the STL and most importantly all your settings. Most likely there's something wrong with the model.
Publié : 31/05/2022 6:53 pm
phil
 phil
(@phil-8)
I have got to the bottom of this. The model was a combination of a mesh and a body in fusion. I had cut the mesh at the plane intersecting the body. This however leaves an open mesh, which apparently prusaslicer doesn't like! it does something really funky and cuts out a random slice, different for each orientation. I've reproduced it and attached the zip for reference
trumpo v3 failed layers
Publié : 31/05/2022 7:33 pm
jsw
 jsw
(@jsw)
My guess is a corrupt model and resulting .stl file, particularly in the way that it cuts off the curved section and appears to omit detail.
Publié : 31/05/2022 8:16 pm
Swiss_Cheese
(@swiss_cheese)
Prusaprinter's File menu? did someone slip on their Freudian? 🤪
the model kinda looks like it has a Negative volume in there, the see through area. We need a project file to know
Ce message a été modifié il y a 4 years 2 fois par Swiss_Cheese
The Filament Whisperer
Publié : 31/05/2022 8:43 pm
Is this any better?
trumpo v2JT
Joan
Publié : 31/05/2022 9:51 pm
PrusaSlicer, Prusaprinters, Printable.… the world is getting too complicated for me 😬
Publié : 31/05/2022 10:15 pm
1 personnes ont aimé
phil
 phil
(@phil-8)
Much better, do you mind explaining how you fixed it?
Publié : 01/06/2022 8:24 am
I opened the project file in Prusa Slicer using windows10,
that brought up orange triangles with exclamation marks in them
I then  clicked on the triangle and used  netfabb to fix the errors.
Publié : 01/06/2022 1:08 pm
