Slicer is adding unwanted infill as if part was solid. Any Suggestions?
[Risolto] Slicer is adding unwanted infill as if part was solid. Any Suggestions?
Jay
 Jay
(@jay-4)
I'm trying to print a part that looks like the image below. (cross-section view and a view tilted up looking at the bottom/inside of the part.)
The last image shows how PrusaSlicer is trying to put infill as if the part was solid.  any suggestions would be greatly appreciated.
Thanks
Jay
Postato : 29/06/2021 7:23 pm
RE: Slicer is adding unwanted infill as if part was solid. Any Suggestions?
See my reply in your duplicate post.
Postato : 29/06/2021 7:36 pm
1 persone hanno apprezzato
Hi Jay, there is probably an error in the STL.
are you using a windows computer?
right click on the model and choose "Fix through the Netfabb"!
Postato : 29/06/2021 7:38 pm
Lichtjaeger
(@lichtjaeger)
This is usually because of a non-manifold body or bad face orientations in your file. (OpenSCAD? FreeCAD?)
You can try to repair it automatically with Netfabb or semi-automatically/manually with Blender.
Jay
 Jay
(@jay-4)
Thank you all for your help in diagnosing this.  You're all correct, the issue was with my CAD file and not Slicer.  I had a duplicate surface in my CAD I couldn't see causing the problem.  I deleted the surface and saved a new .stl.  Problem solved.
Thank you all for taking the time to help me out.  Very much appreciated!
Jay
Postato : 29/06/2021 8:33 pm
