RE: Skirt printed under the model
The bottom of your model is not flat to the bed. If you look at your layer preview you will see that if you only show the first layer.
Use the place to face tool to make it lay to the bed. If that doesn’t work then there have been a couple of instances where Prusa Slicer has had trouble. I recall seeing the issue mentioned on GitHub. If that is the case placing on an alternate face and then back to the one you want can sometimes work.
Postato : 05/11/2020 2:25 pm
Topic starter
answered:
Oups, many thanks, you are right. Not flat on the bed.
Postato : 05/11/2020 8:13 pm
