Skirt printed under the model
michel.g8
(@michel-g8)
Hello,
Once in a while I get a skirt placed under my model by PrusaSlicer 2.20.
I use a Mac (macOS Mojave 10.14.6) and the latest firmware on a Prusa i3 MK3.
Please see attached images.
Any suggestion as why this happens?
Thank you,
Michel
Posted : 05/11/2020 1:11 pm
RE: Skirt printed under the model
The bottom of your model is not flat to the bed. If you look at your layer preview you will see that if you only show the first layer.
Use the place to face tool to make it lay to the bed.  If that doesn’t work then there have been a couple of instances where Prusa Slicer has had trouble. I recall seeing the issue mentioned on GitHub. If that is the case placing on an alternate face and then back to the one you want can sometimes work.
Posted : 05/11/2020 2:25 pm
michel.g8
(@michel-g8)
Oups, many thanks, you are right. Not flat on the bed.
Posted : 05/11/2020 8:13 pm
