Single extruder, multi matertial - Tool selection (T0, T1)
Pasubio
(@pasubio)
the issue apply to multi color printing on a single nozzle, through manual filament change while print is in pause.)
I'm using a non-IDEX dual extruder machine (T0 and T1 tools, RepRap Firmware on Duet board), and I mainly use the second extruder, the T1 one, so in the Start Gcode Script I use "T1" as first command. This is ok for single-material printing, because PE do not introduce "T" commands while using the default extruder.
The problems arise when I need to print with multiple colors, because while enabling 2 extruders and the Multi Material Single Extruder option PE automatically insert "T0" command just after my custom Start Gcode Script.
This behaviour is really annoying because I need to manually clean the Gcode before loading it up to the printer
Do you have any ideas in order to circumvent this problem?
Thank you!
Postato : 27/09/2021 8:40 am
jkavalik
(@jkavalik)
Utenti
Custom toolchange gcode
Does it generate the "T0" even if you add a custom toolchange code?
Postato : 27/09/2021 10:01 am
Pasubio
(@pasubio)
RE: Single extruder, multi matertial - Tool selection (T0, T1) and toolchange Gcode
Hi Jkavalik,
Yes, it generate the "T0" also when adding a custom toolchange code (ex. "M600").
Moreover, PE introduce that custom code also at the beginning of the Gcode file, just before the Start Gcode Script: I think that this behaviour is useless because I'm really not changing tool when the print start.
Thank you!
Questo post è stato modificato 5 years fa da Pasubio
Postato : 28/09/2021 9:21 am
Although it's not quite the same topic the issue is addressed in this thread:
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
Postato : 28/09/2021 12:49 pm
Pasubio
(@pasubio)
RE: Single extruder, multi material - Tool selection (T0, T1) and toolchange Gcode - Workaround
I found a post-processing workaround by the user Jacotheron.
Anyway I think that PS should fix that issues:
  • Maybe letting user to select the tool number for each extruder, allowing also the same value for each extruder.
  • Avoiding the insertion of the Custom Toolchange Code for the first activated nozzle at the the start of the printing process.
Thank you.
https://forum.prusa3d.com/forum/prusaslicer/perl-post-processing-strip-t-commands-for-a-message-and-m600/
https://github.com/prusa3d/PrusaSlicer/issues/4644
Postato : 29/09/2021 8:28 am
