Show effective config
blalor
(@blalor)
Gcode for a set of objects is generated from print settings, filament settings, and printer settings, with some parameters overriding others (like retraction settings in the filament overriding the extruder’s). Is there my way to see what the effective parameters are that are used by the slicing engine when taking into account the overrides?
Napsal : 22/05/2020 10:08 pm
RE: Show effective config
Hi Blalor,
the config used to slice a particular model, is added to the end of the Gcode.
regards  Joan
Napsal : 22/05/2020 10:44 pm
blalor
(@blalor)
I see config settings like `filament_wipe` and also `wipe`, which match with the filament overrides and extruder settings.  Those represent the various settings used to configure the print, but not the values used by the slicer to compute the gcode.
Napsal : 22/05/2020 10:48 pm
