Sequential material change
Hello everyone, maybe this is so easy to do, but I could not find how.I need to print a part that will consist of filaments of different properties, and not in color, but in properties. Several layers of PETG, several layers of PC \ ABS and so on (in one case, airflow is needed, in the other it is not needed). Accordingly, it would be very useful to select the desired bar from those that have already been added to the slicer, after adding a "color change" for the selected range of layers, the ability to select a pre-configured bar.
Publié : 09/07/2023 9:44 am
Topic starter
answered:
RE: Sequential material change
Ideally, it would be possible to choose which print settings / bar settings profiles are needed for the selected layers
Publié : 09/07/2023 12:47 pm
