Scarring when moving between ironed parts in "Complete Individual Objects" mode
Sanworks
(@sanworks)
Mitglied
I'm having an issue where the slicer fails to insert a Z-hop in the final move to begin the next part after ironing the first part in "Complete Individual Objects" mode.
This results in a scar on the ironed surface.
I'm using the Prusa Slicer default settings for the "0.2mm structural" profile with the following overrides:
- Enable Ironing + Topmost Surface Only
- Generate Support Material
- Complete Individual Objects
I'm using Prusa Slicer 2.9.2 on Win10 with Core One.
Thanks!
Dieses Thema wurde geändert Vor 10 months von Sanworks
Veröffentlicht : 12/07/2025 6:58 pm
Nicholas Borge
(@nicholas-borge)
Mitglied
RE: Scarring when moving between ironed parts in "Complete Individual Objects" mode
I'm having the same issue 🙁
Veröffentlicht : 08/01/2026 3:50 pm
Träd-E
(@trad-e)
You could probably inject some custom G-code for the lift but that's generally unadvisable unless you know exactly what you're doing... probably you should make a bug report on prucaslicer git...
Veröffentlicht : 09/01/2026 8:15 pm
This has zero to do with ironing or with complete individual objects.  It will do the same even without those settings when printing multiple objects.
Check that you don't have ramping lift enabled.  The setting is under Printers>Extruder 1>Travel Lift.  But also check your filament profile as that's also an option in the Filament Overrides section.
This little nugget of info was found by ClayShoaf and mentioned in this issue on the PS github https://github.com/prusa3d/PrusaSlicer/issues/12764
Veröffentlicht : 09/01/2026 10:26 pm
