Same bed temp for the first 3 layers, But How?
SiF1
 SiF1
(@sif1)
In PrusaSlicer i can only change the bed print temp for the first layer and that's just not helping as i need to lower the temps on layer 3 or even 4, If i lower the bed temp after the first layer then the prints start to peel up, if i lower the bed temp after layer 3 or 4 then all is ok.
So my question is Can prusaslicer even do this? If so how?
TIA
Best Answer by Robin:
You can add "custom gcode" to a layer of your choosing directly in slicer. Just slice your object then move the layer slider right side of the view to the correct layer and right click the (+) to add "custom gcode", use  M140 for bed temp ( https://marlinfw.org/docs/gcode/M140.html )
Veröffentlicht : 07/02/2022 2:05 pm
PapaYankee
(@papayankee)
RE: Same bed temp for the first 3 layers, But How?
Hello,
I did not test it, but I would add a M140 (with bed temperature) at the proper layer change. It should do the job.
Veröffentlicht : 07/02/2022 10:09 pm
towlerg
(@towlerg)
Just to expand the previous post, look in the .GCode file for the text ;LAYER_CHANGE (which appears at the start of each layer).
Veröffentlicht : 08/02/2022 12:00 pm
Robin
(@robin)
Veröffentlicht : 08/02/2022 12:42 pm
SiF1
 SiF1
(@sif1)
Thanks guys, this is just what i needed.
I added "M140 S45;" on the layer i wanted the bed to cool down a bit and bingo 👍🍻
Veröffentlicht : 08/02/2022 1:26 pm
