Running custom G-code at a specific layer number and for a specific filament
jphalip
(@jphalip)
I'd like to run a G-Code macro in Klipper when the print reaches a specific layer number, and when a specific filament is used. For example, "If it's the 4th layer and the filament is PLA, then run this macro".
I figure this might be possible by tweaking the printer settings under Custom G-code > Before layer change, but I can't quite figure out how.
Do you have some tips?
Thanks in advance!
Julien
Veröffentlicht : 10/05/2023 10:21 pm
RE: Running custom G-code at a specific layer number and for a specific filament
Just add the following.
{if layer_num == 3 && filament_type[0] == "PLA"} M117 INSERT ME {endif} ; This will insert the 'M117 INSERT ME' line on layer 4 if the filament type is PLA (configured as that in the filament settings. Layers are numbered from zero so the 4th layer is 3
into the custom before layer gcode filed under Printer Settings.  It will be up to you to tiee this into whatever Klipper setup you have.
Veröffentlicht : 10/05/2023 11:10 pm
jphalip
(@jphalip)
Perfect, thanks so much!
Also, the per-layer custom gcode feature is only available in printer settings and isn't supported in the filament settings yet, correct?
Veröffentlicht : 11/05/2023 12:32 am
Correct. What’s available in different areas is dependant on the version of Prusa Slicer you are running.  There is a table in the Prusa Slicer Knowledgebase that lists what is and isn’t in 2.5 and the 2.6 alphas.
Veröffentlicht : 11/05/2023 5:11 am
Found the table I mentioned https://help.prusa3d.com/article/list-of-placeholders_205643
Veröffentlicht : 11/05/2023 6:44 am
