Report a little bug on PrusaSlicer 2.4 with Z offset
Salvatore Elio Giachinta
(@salvatore-elio-giachinta)
Hi, I'm not very good with bed leveling so I need to set a 0.05mm Z offset.With PrusaSlicer 2.3.3 I didn't have any problems.Today I installed PrusaSlicer 2.4 and I sliced ​​with 0.2mm high layers, I see a first empty 0.2mm ghost layer while the 0.25mm layer is indicated as the second layer.
This topic was modified 4 years temu by Salvatore Elio Giachinta
Opublikowany : 04/01/2022 9:51 am
RE: Report a little bug on PrusaSlicer 2.4 with Z offset
This is a user to user forum.  All bug reports should be made on the Prusa Slicer github, located here https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc   if you actually want to report an issue.
Opublikowany : 04/01/2022 12:38 pm
1 ludzie polubili
