Report a little bug on PrusaSlicer 2.4 with Z offset
Hi, I'm not very good with bed leveling so I need to set a 0.05mm Z offset.With PrusaSlicer 2.3.3 I didn't have any problems.Today I installed PrusaSlicer 2.4 and I sliced with 0.2mm high layers, I see a first empty 0.2mm ghost layer while the 0.25mm layer is indicated as the second layer.
Ce sujet a été modifié il y a 4 years par Salvatore Elio Giachinta
Publié : 04/01/2022 9:51 am
RE: Report a little bug on PrusaSlicer 2.4 with Z offset
This is a user to user forum. All bug reports should be made on the Prusa Slicer github, located here https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc if you actually want to report an issue.
Publié : 04/01/2022 12:38 pm
1 personnes ont aimé
