Repeated logouts in Prusa Connect
samuel-t
(@samuel-t)
I'm repeatedly being logged out of Prusa Connect (the same issue occurs with the Prusa app). It's quite frustrating, especially with 2FA enabled, as I have to go through the entire login process over and over again. This often happens when I close the slicer and immediately reopen it. It also seems to occur when two instances of the slicer are running simultaneously.
Any idea if this is a known issue? Does it happen to other users as well?
Best Answer by Neophyl:
Yes it is a known issue.  For example https://github.com/prusa3d/PrusaSlicer/issues/13944 https://github.com/prusa3d/PrusaSlicer/issues/13883 https://github.com/prusa3d/PrusaSlicer/issues/13939
Its supposed to be fixed in 2.9.1 alpha 1  https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.9.1-alpha1   for the release notes but here's an excerpt
Windows specific: Fixed unexpected re-login without entering user credentials to Prusa Account after the user logged out. The token was not cleared on logout in all cases.
Fixed printing order of open perimeters with Arachne perimeter generator, which led to excessive travel moves. #11658Fixed a rare crash when downloading avatar icon from PrusaAccount.
There were multiple issues related to frequent logouts from Prusa Account. Most of them should now be fixed. Probably the most frequent issue was related to having multiple instances of PrusaSlicer running (in simple terms, one instance might logout another). The login status is now shared across instances in the sense that whatever the user does in any of the instances happens in all of them. #13944, #13883, #13939
In some cases, Connect tab in PrusaSlicer would become all white and unable to recover without restarting the application. This should now be fixed, although several different things can cause this. #14138 #14028 #14016
Its also common to be logged out the forum.  Seems to be a theme with Prusa.
Respondido : 04/03/2025 9:14 am
RE: Repeated logouts in Prusa Connect
Respondido : 04/03/2025 10:15 am
That whole user authentication approach they're using is a total mess. Being logged out is just part of life with Prusa ☹️ It's even worse if you have different accounts for say the forum and the prusa3d site because most of the time when you click on login you get logged in automatically without seeing the login screen—and alas, apparently randomly to one of those accounts, and of course usually the wrong one.
Respondido : 04/03/2025 12:42 pm
