Remove Printers from config?
Frank
(@frank-8)
I recently got in trouble when I tried to print something with the wrong printer configuration selected. Instead of Prusa MK3S+, I had 'CreatorPro2' selected.  Needless to say, that did not end well.
I think the 'CreatorPro2' stuff is left over from when I was trying (unsuccessfully) to build a CreatorPro2 'package' for the Prusa Slicer.  Now I want to remove them, but can't seem to find an easy way to do that.  I can 'add' printers, but apparently I can't subtract them.
Any clues?
TIA,
Frank
Postato : 15/02/2022 7:11 pm
JimB
 JimB
(@jimb)
RE: Remove Printers from config?
Near top-right, expand Printer menu and select Add/Remove Printers, then Add/Remove Presets.  Select Other Vendors and then uncheck Creality.  (If you have some Creality printer you want to keep, but just delete the Pro2, then select Creality FFF on left and find the ones you don't want and unselect them.)  Then Finish.
Postato : 15/02/2022 8:01 pm
Printers and other items added using the wizard can only be removed by using the configuration wizard.  Custom ones you have added manually like any other profile can be removed using the X delete icon next to the selection drop down.  The delete X is only shown on your custom ones.  That is the same for all types of profiles, Print, Filament and Printers.
Postato : 15/02/2022 8:31 pm
Frank
(@frank-8)
Thanks - I found the entry for the 'CreatorPro2 Family, and I see where I can remove it by unchecking the '0.4mm nozzle' checkbox.  I was worried that I had somehow screwed things up when I tried to roll my own CreatorPro2 printer section, but apparently someone else actually succeeded in doing this.
Is there any way to find out who added these printer presets - I'd love to talk to them and maybe help if I can.
TIA,
Frank
Postato : 15/02/2022 10:09 pm
