Removal of solid infill on a part with zero infill
woodhamsmax
(@woodhamsmax)
Hi All
I am trying to print a RC wing with zero infill, 3 top layers and 4 bottom layers.
Every time I slice, I get a lot of unwanted solid infill. See image:
Can anyone help? Googling leads me to "ensure vertical thickness" which is removed on 2.6.1
Best regards
Max
This topic was modified před 3 years by woodhamsmax
Napsal : 27/10/2023 10:40 am
RE: Removal of solid infill on a part with zero infill
Could you please add a project file, containing this wing section, so that other users can attempt to help you with more than guesses>
Save the project using the file menu in Prusa Slicer, then Zip compress the file, and attach the zip file to your next post, please.
Napsal : 27/10/2023 11:47 am
woodhamsmax
(@woodhamsmax)
Hi Joan. Thanks for the prompt reply. Here is the .3mf file as requested.
wing_test_retract
Regards
Max
Napsal : 27/10/2023 12:04 pm
Hi Max,
is this the correct wing section?
I cant see any internal structure!
Napsal : 27/10/2023 12:54 pm
woodhamsmax
(@woodhamsmax)
Hi Joan. There is some internal structure. Some very thin cuts within the model. A section view will show the detail.
Regards
Max
Napsal : 27/10/2023 1:18 pm
The new 'improved' solid infill code yet again makes things more difficult.  Until they change it to let people properly and FULLY turn it off we have to resort to workarounds with modifiers.
Try the attached project.  Examine the height range modifier.
Go add your support to https://github.com/prusa3d/PrusaSlicer/issues/10102   or https://github.com/prusa3d/PrusaSlicer/issues/10926 or https://github.com/prusa3d/PrusaSlicer/issues/10202   or all of them.
Napsal : 27/10/2023 5:42 pm
Hi Max,
that's a different approach compared to the last wing section that I looked at,
Is this what you are looking for?
wing_test_retract JT
if you want thicker surfaces, you could increase the extrusion width, for external perimeters,
this was another wing section and another slicer configuration
in this version, the slit perforated the undersurface
Wing_C revised JT
Napsal : 27/10/2023 5:46 pm
woodhamsmax
(@woodhamsmax)
Thank you one and all. So much info to digest. I will get back to you soon.
Just wanted to say I really appreciate your time and effort.
Max
Napsal : 27/10/2023 7:32 pm
