Reduce printing speed
Zilerd
(@zilerd)
Recently  install a Stainless Steel nozzle and I want to reduce the print speed by 10%. I know how to do it on the printer but I want to know if there's a way to do it in Prusa slicer. Thanks!
Postato : 06/09/2021 7:18 pm
Change speeds or MVS
If you want to reduce all speeds 10% proportionally, you have to edit the individual speeds (Print settings->Speed). If you'd just like to cap the MAXIMUM speed, you can do so using Maximum volumetric rate. That will set an upper limit on how much filament is fed into the hotend. If your individual speeds are low enough to stay below this level, they will be used. If they result in a higher flow, the MVS limit will be applied. Think of it as a top speed governor. (Set under Print Settings->Speed->Auto Speed->Max volumetric speed.)
Remember that the slicer and printer settings are separate. If you limit speeds in the slicer, the gcode will be created using those speeds. If you then adjust while printing, that is a multiplier applied to whatever is in the gcode. Also remember that changes on your printer are stick and will remain set until you reset or power cycle the printer if you don't reset them in gcode.
Postato : 06/09/2021 7:44 pm
Zilerd
(@zilerd)
Thanks!
I will stick by reducing the Print Settings Speed this volumetric speed sounds more complicated 🤪 . Thank You!
Postato : 07/09/2021 2:06 am
Area51
(@area51)
Utenti
M220 Set Speed Factor
Another (advanced) way is to add a gcode in the startup gcode to set/reduce print speed in PrusaSlicer gcode startup:
M220: Set speed factor override percentage
Example:
M220 S80 ; Will reduce all speeds in gcode to 80%
See reprap.org definition.
Be adware that this setting is in effect until changed or power off/on as @bobstro mentions.
Postato : 07/09/2021 11:40 am
1 persone hanno apprezzato
Zilerd
(@zilerd)
Nice
This is what I was looking for. I will give it a try, Thanks
Postato : 07/09/2021 1:27 pm
Revel
(@revel)
RE: Reduce printing speed
Posted by: @bobstro
I can give this a shot, but it is strange that slicer doesn't change its estimated time regardless of hitting tons of these speed variables with low numbers. 12 in both Auto Speed Advanced and then 40 in most of the Speed for Print Moves is still the same as default for print times.
But if I mess with Dynamic Overhang Speeds it goes way up. Perhaps this is becuase i'm printing a tree? But seems like that Max Print Speed / Max Volumetric Speed should cover everything including that.  The prints that need to be slowed down are stuff like my tree branches, or thing objects in general with overhang.
Postato : 15/01/2025 12:00 am
Zara Bolen
(@zara-bolen)
Utenti
In PrusaSlicer, you can reduce the print speed by adjusting the individual speeds for different movements. To reduce the print speed by 10% overall, you can:
Adjust Print Settings:
Go to Print Settings -> Speed.
Manually reduce each speed setting (e.g., for Print Moves, Infill, etc.) by 10%. For example, if a print move speed is set to 50 mm/s, change it to 45 mm/s.
Use Maximum Volumetric Speed (MVS):
Another method is to set a limit using Max Volumetric Speed (MVS) under Print Settings -> Speed -> Auto Speed -> Max Volumetric Speed.
This acts as a cap to the filament flow rate, effectively reducing the print speed if the speeds you’ve set cause the printer to exceed this flow rate.
Using G-code Command:
If you want to reduce the speed by a percentage in the G-code itself, you can add an M220 command to the startup G-code in PrusaSlicer.
For example, adding M220 S90 will reduce all speeds by 10% (the S90 sets the speed factor to 90% of the original speed).
Each method has its advantages: adjusting the speeds in the slicer provides more control over specific print speeds, while using the MVS or G-code approach can be more flexible for general speed limits or dynamic adjustments.
Postato : 24/07/2025 5:17 am
