Reduce amount of support in hole
Hi all
Im having trouble with amount if support which is generated in side of hole, here is mine old sliced object
And here is how it look like now when I slice it
So how can I reduce amount of support which is in side of that hole ?
Postato : 12/11/2023 1:04 am
RE: Reduce amount of support in hole
Do you need supports in the hole? Looks small enough so that the top can be bridged. You can add a support blocker to keep supports from being added to the hole.
Postato : 12/11/2023 2:06 am
