PusaSlicer 2.9.2 - Cookies Consent - Frozen
kumaichi
(@kumaichi)
Hello, just installed PusaSlicer 2.9.2 and when I try to send to connect, the cookies consent is frozen, can't click any of the buttons, thus not able to send a new print job via connect.  Any way to unlock the consent "dialog"?
Kindest regards
Best Answer by ErikLutz:
It was frozen for me only when using the "Send to Connect" option, when I went to the Prusa Connect tab it showed up there and I was able to actually select an option.
Postato : 17/04/2025 6:06 pm
algesten
(@algesten)
RE: PusaSlicer 2.9.2 - Cookies Consent - Frozen
Same here. I'm stuck.
Postato : 17/04/2025 6:11 pm
jmorrison7
(@jmorrison7)
I am having the same issue, WTF?
Postato : 17/04/2025 6:16 pm
kumaichi
(@kumaichi)
I'm glad it's just not me, because that happens a lot 🤣 .
Postato : 17/04/2025 6:18 pm
algesten
(@algesten)
I really don't expect cookie consent forms in an application. Just stop it with the tracking already.
Postato : 17/04/2025 6:19 pm
ErikLutz
(@eriklutz)
Utenti
Postato : 17/04/2025 6:28 pm
Theuno
(@theuno)
Utenti
I have the issue on 2.9.1
Very annoying! Why are there cookies in my app?
However, opening "Prusa Connect" from the top, and accepting the cookies fixes the issue.
Questo post è stato modificato 1 year fa da Theuno
Postato : 17/04/2025 6:55 pm
Wazoo3d
(@wazoo3d)
Yes me too.. same thing.. how do you get around it?
Postato : 17/04/2025 7:08 pm
Flyintheoil
(@flyintheoil)
Utenti
I was able to get mine "unfrozen" by pretending the boxes where about a half inch lower than they actually display, so it looked like just white space but gave me the ability to click
Postato : 17/04/2025 7:09 pm
3 persone hanno apprezzato
Wazoo3d
(@wazoo3d)
You can click where the confirm button is and continue. You just can't see it because of the message on the screen to accept the cookies.
Postato : 17/04/2025 7:10 pm
Wazoo3d
(@wazoo3d)
Now when I went to Prusa Connect, the dashboard then I could click the buttons on the Cookies Consent buttons.
Postato : 17/04/2025 7:11 pm
kumaichi
(@kumaichi)
This worked for me, thanks!
Posted by: @eriklutz
Postato : 17/04/2025 7:25 pm
1 persone hanno apprezzato
dleezy15
(@dleezy15)
Utenti
That worked. Appreciate it.
Postato : 17/04/2025 8:50 pm
Space Monkey
(@space-monkey)
I’ve got the same issue, I need to consent to cookies to send a file to my printer?
I’ve never had this problem until today.
Postato : 17/04/2025 9:09 pm
SparkyTx
(@sparkytx)
Utenti
I agree with WHY track cookies going to the printer.  The main reason I didn't purchase a Bambu was the having everything tracked by them.  OBTW Thanx to eriklutz for the work around.
Postato : 17/04/2025 9:29 pm
Wazoo3d
(@wazoo3d)
No, but you need to select 1 of the options to remove the message. Go to Prusa connect tab at top you should than be able to select 1 of the options.
Postato : 17/04/2025 9:40 pm
Buluk
(@buluk)
Utenti
Exact same issue for me too, it started to fail recently.
Any plans to fix it soon ?
At least the solution to click first in prusa connect helped, nethertheless it's really annoying. better not track anything (cookies) than bug users.
Questo post è stato modificato 1 year fa da Buluk
Postato : 18/04/2025 7:02 am
LarGriff
(@largriff)
This kind of thing is what worries me most about Prusa products.  Not knowing whether your printer will be suddenly crippled by the next update.  I’d hate to be dependent on a farm of them!
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Postato : 18/04/2025 8:56 am
