Purge Line settings difference between MK4 and Mini
JBinFL
(@jbinfl)
Hello all:
I have a question
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Napsal : 17/11/2024 3:10 pm
JBinFL
(@jbinfl)
RE: Purge Line settings difference between MK4 and Mini
Ok, somehow I lost everything I just typed... 😫
I would like to know if i can modify the Mini purge line settings to resemble that of the MK4 and have the Mini do the same "swirl" purge that the MK4 does.  the MK4 starts purging filament as the print head moves towards the steel sheet and it makes for a very clean purge.  The Mini does the same type of purge that it always does, just a straight line once the print head reaches the plate.
I am unsure if it is only the difference in the printer custom Start G-code commands in PrusaSlicer or if there is a mechanical difference in the steppers between the MK4 and Mini that allows the MK4 to do the swirls when purging that the Mini would not be able to do.
I pasted the two different areas of the custom G-Code in the printer tab of PrusaSlicer for Start G-Code below to show the difference.
Do I have the right thing to copy paste?  just copy from MK4 start print custom Gcode and paste to the mini and that would work?
MK4 Custom G-Code instructions from PrusaSlicer
; prepare for purgeM104 S{first_layer_temperature[0]}G0 X0 Y-4 Z15 F4800 ; move away and ready for the purgeM109 S{first_layer_temperature[0]}
G92 E0M569 S0 E ; set spreadcycle mode for extruder
;; Extrude purge line;
G92 E0 ; reset extruder position
G1 E{(filament_type[0] == "FLEX" ? 4 : 2)} F2400 ; deretraction after the initial one before nozzle cleaning
G0 E7 X15 Z0.2 F500 ; purge
G0 X25 E4 F500 ; purge
G0 X35 E4 F650 ; purge
G0 X45 E4 F800 ; purge
G0 X48 Z0.05 F8000 ; wipe, move close to the bed
G0 X51 Z0.2 F8000 ; wipe, move quickly away from the bed
G92 E0
Mini Custom G-Code instructions from PrusaSlicer
M109 S[first_layer_temperature] ; wait for extruder temp
; intro line
G1 X10 Z0.2 F1000
G1 X70 E8 F900
G1 X140 E10 F700
G92 E0
Napsal : 17/11/2024 3:45 pm
_KaszpiR_
(@_kaszpir_)
Yes, you can copy fragment of start gcode from MK4 printer profile and paste it instead of the current fragment in the Mini profile.
Mini has single line purge with a comment as you pasted.
Notice that Mini probably does not need that line:
Also notice you pasted gcode and some newline chars were removed.
One more thing, at the start there is move to X0 Y-4 which may be outside of the print sheet, so you may need to tweak it to something like G1 X10 Y-4
Also remember to save it as new profile so that the original one will not be overwritten on next profile update.
Hmmm looking at the that MK4 gcode it just does short purge line, no swirls because there are no Y moves...
Napsal : 17/11/2024 7:41 pm
JBinFL
(@jbinfl)
KaszpiR:
Thank you!
Yes, my pasting format got screwed up, and I had lost the in-depth info in my first post somehow...  I think I lost my mind and tried to attach a file instead of putting the picture in the post...  The copy paste from PrusaSlicer screwed up the formatting...
I am not a coder at all and and only have a general superficial awareness of how it works at best.  That was why I was a bit worried to experiment with changing the start G-code, but as you suggest I will save as a copy so as not to mess up my original...  So, I should not be worried.
I have never messed with my start G-code profile info, that is how it came when I installed PrusaSlicer and upgraded it...  it definitely does little circles on the MK4 purge, I am running a quick print to get a picture to post to show.
Below are pictures of the MK4 purge line and Mini purge line, note how the MK4 starts up in the air, but it definitely makes little circles in real life.  the Mini purge line is just a line.
Napsal : 17/11/2024 10:58 pm
