PruserSlicer 2.5.0 MacOS quits instantly
[Resuelto] PruserSlicer 2.5.0 MacOS quits instantly
Ian Meikle
(@ian-meikle)
Just downloaded the new PruserSlicer 2.5.0 and installed it.
However, once I try and open it, it just quits instantly. No error message apart from the standard "The Application quite unexpectedly".
I have tried to delete the App and reinstall it, but get the same problem 🙁
I am on a MacBook Pro with a M1 chip
How can I find out why it is quitting and how to fix it ?
Thanks
Ian
Este debate ha sido modificado el hace 3 years 2 veces por Ian Meikle
Respondido : 22/01/2023 2:33 pm
Ian Meikle
(@ian-meikle)
RE: PruserSlicer 2.5.0 MacOS quits instantly
These are the details it offers to send to if I click "Send to Apple"
Translated Report (Full Report Below)
Process:               PrusaSlicer [19987]
Path:                  /private/var/folders/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicer
Identifier:            com.prusa3d.slic3r/
Version:               PrusaSlicer PrusaSlicer-2.5.0+MacOS-x64-202209060719 (PrusaSlicer-2.5.0+MacOS-x64-202209060719)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2023-01-22 15:33:47.4877 +0100
OS Version:            macOS 13.0.1 (22A400)
Report Version:        12
Anonymous UUID:        9B7E0982-A4C2-518B-3D62-146F0B181BA2
Sleep/Wake UUID:       23830388-EA04-4AFA-99F0-CBD477044BF8
Time Awake Since Boot: 1200000 seconds
Time Since Wake:       922 seconds
System Integrity Protection: enabled
Crashed Thread:        0  slic3r_main  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000014
Exception Codes:       0x0000000000000001, 0x0000000000000014
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [19987]
VM Region Info: 0x14 is not in any region.  Bytes before following region: 105553518919660
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      MALLOC_NANO (reserved)   600018000000-600020000000 [128.0M] rw-/rwx SM=NUL  ...(unallocated)
Kernel Triage:
VM - pmap_enter retried due to resource shortage
Thread 0 Crashed:: slic3r_main Dispatch queue: com.apple.main-thread
0   PrusaSlicer                   	       0x106f311ac ImFont::CalcTextSizeA(float, float, float, char const*, char const*, char const**) const + 88
1   PrusaSlicer                   	       0x106f31314 ImFont::CalcTextSizeA(float, float, float, char const*, char const*, char const**) const + 448
2   PrusaSlicer                   	       0x106ede2a4 ImGui::CalcTextSize(char const*, char const*, bool, float) + 140
3   PrusaSlicer                   	       0x105942894 Slic3r::GUI::NotificationManager::HintNotification::count_spaces() + 44
4   PrusaSlicer                   	       0x105943e34 Slic3r::GUI::NotificationManager::HintNotification::init() + 44
5   PrusaSlicer                   	       0x105944e80 Slic3r::GUI::NotificationManager::HintNotification::retrieve_data(bool) + 408
6   PrusaSlicer                   	       0x10591fc44 Slic3r::GUI::NotificationManager::HintNotification::HintNotification(Slic3r::GUI::NotificationManager::NotificationData const&, Slic3r::GUI::NotificationManager::NotificationIDProvider&, wxEvtHandler*, bool) + 108
7   PrusaSlicer                   	       0x10591d158 Slic3r::GUI::NotificationManager::push_hint_notification(bool) + 268
8   PrusaSlicer                   	       0x1056b324c Slic3r::GUI::GUI_App::post_init() + 1332
9   PrusaSlicer                   	       0x1056cd0ec wxEventFunctorFunctor<wxEventTypeTag<wxIdleEvent>, Slic3r::GUI::GUI_App::on_init_inner()::$_4>::operator()(wxEvtHandler*, wxEvent&) + 64
10  PrusaSlicer                   	       0x107264fac wxEvtHandler::SearchDynamicEventTable(wxEvent&) + 252
11  PrusaSlicer                   	       0x107264ca4 wxEvtHandler::ProcessEventLocally(wxEvent&) + 92
12  PrusaSlicer                   	       0x107264b00 wxEvtHandler::ProcessEvent(wxEvent&) + 56
13  PrusaSlicer                   	       0x1071cc354 wxAppConsoleBase::ProcessIdle() + 92
14  PrusaSlicer                   	       0x107011dfc wxAppBase::ProcessIdle() + 24
15  PrusaSlicer                   	       0x107160e4c wxApp::ProcessIdle() + 36
16  PrusaSlicer                   	       0x10726d2f4 wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*) + 124
17  CoreFoundation                	       0x188f34de4 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 36
18  CoreFoundation                	       0x188f34cd0 __CFRunLoopDoObservers + 532
19  CoreFoundation                	       0x188f34410 __CFRunLoopRun + 1048
20  CoreFoundation                	       0x188f338a4 CFRunLoopRunSpecific + 612
21  HIToolbox                     	       0x1925a73bc RunCurrentEventLoopInMode + 292
22  HIToolbox                     	       0x1925a7200 ReceiveNextEventCommon + 672
23  HIToolbox                     	       0x1925a6f48 _BlockUntilNextEventMatchingListInModeWithFilter + 72
24  AppKit                        	       0x18c18c630 _DPSNextEvent + 632
25  AppKit                        	       0x18c18b7c0 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 728
26  AppKit                        	       0x18c17fbf0 -[NSApplication run] + 464
27  PrusaSlicer                   	       0x107197880 wxGUIEventLoop::OSXDoRun() + 160
28  PrusaSlicer                   	       0x10726d9b8 wxCFEventLoop::DoRun() + 40
29  PrusaSlicer                   	       0x1071f0544 wxEventLoopBase::Run() + 112
30  PrusaSlicer                   	       0x1071cc14c wxAppConsoleBase::MainLoop() + 120
31  PrusaSlicer                   	       0x107160ea8 wxApp::OnRun() + 36
32  PrusaSlicer                   	       0x10721ca2c wxEntry(int&, wchar_t**) + 148
33  PrusaSlicer                   	       0x1056a8c5c Slic3r::GUI::GUI_Run(Slic3r::GUI::GUI_InitParams&) + 292
34  PrusaSlicer                   	       0x104e3f9cc Slic3r::CLI::run(int, char**) + 16348
35  PrusaSlicer                   	       0x104e44164 main + 204
36  dyld                          	       0x188b2be50 start + 2544
Thread 1:
0   libsystem_pthread.dylib       	       0x188e50e18 start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:: com.apple.NSEventThread
0   libsystem_kernel.dylib        	       0x188e16df0 mach_msg2_trap + 8
1   libsystem_kernel.dylib        	       0x188e288d8 mach_msg2_internal + 80
2   libsystem_kernel.dylib        	       0x188e1f638 mach_msg_overwrite + 540
3   libsystem_kernel.dylib        	       0x188e1716c mach_msg + 24
4   CoreFoundation                	       0x188f35bdc __CFRunLoopServiceMachPort + 160
5   CoreFoundation                	       0x188f344c8 __CFRunLoopRun + 1232
6   CoreFoundation                	       0x188f338a4 CFRunLoopRunSpecific + 612
7   AppKit                        	       0x18c2b6248 _NSEventThread + 172
8   libsystem_pthread.dylib       	       0x188e5606c _pthread_start + 148
9   libsystem_pthread.dylib       	       0x188e50e2c thread_start + 8
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 0 crashed with ARM Thread State (64-bit):
    x0: 0x0000000000000001   x1: 0x00000001079b6d10   x2: 0x000000000000000e   x3: 0x0000000188e81643
    x4: 0x0000000000000003   x5: 0x0000000000003c30   x6: 0x0000000000000029   x7: 0x00006000023ab0f0
    x8: 0x0000000000000000   x9: 0x000000007f7fffff  x10: 0x0000e55c9aa00000  x11: 0x00006000023a8000
   x12: 0x0000000000000030  x13: 0x00000000001ff800  x14: 0x00000000000007fb  x15: 0x00000000b680d142
   x16: 0x0000000188e81700  x17: 0x00000001e9364ef0  x18: 0x0000000000000000  x19: 0x0000000000000000
   x20: 0x0000000000000000  x21: 0x00000001079b6d1e  x22: 0x00000001079b6d1d  x23: 0x000000016afc54b8
   x24: 0x0000000107cd5d28  x25: 0x0000600002832d20  x26: 0x0000600001dd9a40  x27: 0x0000600000830840
   x28: 0x000000010726d278   fp: 0x000000016afc53b0   lr: 0x0000000106f31314
    sp: 0x000000016afc5320   pc: 0x0000000106f311ac cpsr: 0x20001000
   far: 0x0000000000000014  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x104e34000 -        0x107a97fff com.prusa3d.slic3r/ (PrusaSlicer PrusaSlicer-2.5.0+MacOS-x64-202209060719) <fce5a1f3-abc2-350d-9665-5a31c4451f80> /private/var/folders/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicer
       0x188eb4000 -        0x18938bfff com.apple.CoreFoundation (6.9) <f4ff83fc-e62c-30b4-b3a9-876c8a1fd595> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x192575000 -        0x1928a8fff com.apple.HIToolbox (2.1.1) <02b9797f-c47d-30b7-b7b0-802d0d26f31c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
       0x18c153000 -        0x18d05afff com.apple.AppKit (6.9) <af9f6891-70ad-3c26-af08-b747344892d2> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x188b26000 -        0x188bb04bf dyld (*) <de46dd52-4994-3fd8-b4b4-e352a1a19354> /usr/lib/dyld
       0x188e4f000 -        0x188e5bffb libsystem_pthread.dylib (*) <886caca0-5762-3640-8db2-3fa3b911c062> /usr/lib/system/libsystem_pthread.dylib
       0x188e16000 -        0x188e4effb libsystem_kernel.dylib (*) <6d6644d3-3db3-34c4-b1e3-c675ec5360f0> /usr/lib/system/libsystem_kernel.dylib
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)
Writable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               640K        5
Activity Tracing                   256K        1
CG backing stores                 4032K        4
CG image                          7424K       44
CG raster data                      80K        1
ColorSync                          608K       27
CoreAnimation                    178.6M       98
CoreGraphics                        16K        1
CoreGraphics (reserved)             16K        1         reserved VM address space (unallocated)
CoreImage                           80K        5
CoreUI image data                 3472K       27
Foundation                          16K        1
Kernel Alloc Once                   32K        1
MALLOC                           309.8M       55
MALLOC guard page                  192K        9
MALLOC_MEDIUM (reserved)         960.0M        8         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        256K        3
STACK GUARD                       56.2M       12
Stack                             13.8M       12
VM_ALLOCATE                        816K       27
__AUTH                             862K      211
__AUTH_CONST                      16.3M      396
__CTF                               756        1
__DATA                            6920K      383
__DATA_CONST                      18.8M      398
__DATA_DIRTY                       978K      131
__FONT_DATA                        2352        1
__GLSLBUILTINS                    5174K        1
__LINKEDIT                       783.9M        5
__OBJC_CONST                      1833K      176
__OBJC_RO                         65.1M        1
__OBJC_RW                         1981K        1
__TEXT                           412.5M      419
dyld private memory                304K        3
mapped file                      186.1M       26
shared memory                     1424K       17
TOTAL                              3.3G     2513
TOTAL, minus reserved VM space     2.0G     2513
Full Report
{"app_name":"PrusaSlicer","timestamp":"2023-01-22 15:33:47.00 +0100","app_version":"PrusaSlicer PrusaSlicer-2.5.0+MacOS-x64-202209060719","slice_uuid":"fce5a1f3-abc2-350d-9665-5a31c4451f80","build_version":"PrusaSlicer-2.5.0+MacOS-x64-202209060719","platform":1,"bundleID":"com.prusa3d.slic3r\/","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.0.1 (22A400)","roots_installed":0,"name":"PrusaSlicer","incident_id":"453D1708-5155-4C1D-94E8-7F58FE8C9CD0"}
  "uptime" : 1200000,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro18,1",
  "coalitionID" : 104335,
  "osVersion" : {
    "train" : "macOS 13.0.1",
    "build" : "22A400",
    "releaseType" : "User"
  "captureTime" : "2023-01-22 15:33:47.4877 +0100",
  "incident" : "453D1708-5155-4C1D-94E8-7F58FE8C9CD0",
  "pid" : 19987,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2023-01-22 15:33:46.4164 +0100",
  "procStartAbsTime" : 29180701602981,
  "procExitAbsTime" : 29180727184725,
  "procName" : "PrusaSlicer",
  "procPath" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/MacOS\/PrusaSlicer",
  "bundleInfo" : {"CFBundleShortVersionString":"PrusaSlicer PrusaSlicer-2.5.0+MacOS-x64-202209060719","CFBundleVersion":"PrusaSlicer-2.5.0+MacOS-x64-202209060719","CFBundleIdentifier":"com.prusa3d.slic3r\/"},
  "storeInfo" : {"deviceIdentifierForVendor":"763A2544-8A3E-543C-8920-D3D4A1ED3CEF","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.prusa3d.slic3r\/",
  "crashReporterKey" : "9B7E0982-A4C2-518B-3D62-146F0B181BA2",
  "wakeTime" : 922,
  "sleepWakeUUID" : "23830388-EA04-4AFA-99F0-CBD477044BF8",
  "sip" : "enabled",
  "vmRegionInfo" : "0x14 is not in any region.  Bytes before following region: 105553518919660\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      MALLOC_NANO (reserved)   600018000000-600020000000 [128.0M] rw-\/rwx SM=NUL  ...(unallocated)",
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000014","rawCodes":[1,20],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000014"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":19987},
  "ktriageinfo" : "VM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\nVM - pmap_enter retried due to resource shortage\n",
  "vmregioninfo" : "0x14 is not in any region.  Bytes before following region: 105553518919660\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      MALLOC_NANO (reserved)   600018000000-600020000000 [128.0M] rw-\/rwx SM=NUL  ...(unallocated)",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":12296083,"threadState":{"x":[{"value":1},{"value":4422593808,"symbolLocation":133795,"symbol":"TextValue::ArgType2"},{"value":14},{"value":6591878723},{"value":3},{"value":15408},{"value":41},{"value":105553153667312},{"value":0},{"value":2139095039},{"value":252185893928960},{"value":105553153654784},{"value":48},{"value":2095104},{"value":2043},{"value":3061895490},{"value":6591878912,"symbolLocation":0,"symbol":"_platform_strlen"},{"value":8207617776},{"value":0},{"value":0},{"value":0},{"value":4422593822,"symbolLocation":133809,"symbol":"TextValue::ArgType2"},{"value":4422593821,"symbolLocation":133808,"symbol":"TextValue::ArgType2"},{"value":6089888952},{"value":4425866536,"symbolLocation":0,"symbol":"wxAppConsoleBase::ms_appInstance"},{"value":105553158417696},{"value":105553147566656},{"value":105553124853824},{"value":4414952056,"symbolLocation":0,"symbol":"wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*)"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4411560724},"cpsr":{"value":536875008},"fp":{"value":6089888688},"sp":{"value":6089888544},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4411560364,"matchesCrashFrame":1},"far":{"value":20}},"name":"slic3r_main","queue":"com.apple.main-thread","frames":[{"imageOffset":34591148,"symbol":"ImFont::CalcTextSizeA(float, float, float, char const*, char const*, char const**) const","symbolLocation":88,"imageIndex":0},{"imageOffset":34591508,"symbol":"ImFont::CalcTextSizeA(float, float, float, char const*, char const*, char const**) const","symbolLocation":448,"imageIndex":0},{"imageOffset":34251428,"symbol":"ImGui::CalcTextSize(char const*, char const*, bool, float)","symbolLocation":140,"imageIndex":0},{"imageOffset":11593876,"symbol":"Slic3r::GUI::NotificationManager::HintNotification::count_spaces()","symbolLocation":44,"imageIndex":0},{"imageOffset":11599412,"symbol":"Slic3r::GUI::NotificationManager::HintNotification::init()","symbolLocation":44,"imageIndex":0},{"imageOffset":11603584,"symbol":"Slic3r::GUI::NotificationManager::HintNotification::retrieve_data(bool)","symbolLocation":408,"imageIndex":0},{"imageOffset":11451460,"symbol":"Slic3r::GUI::NotificationManager::HintNotification::HintNotification(Slic3r::GUI::NotificationManager::NotificationData const&, Slic3r::GUI::NotificationManager::NotificationIDProvider&, wxEvtHandler*, bool)","symbolLocation":108,"imageIndex":0},{"imageOffset":11440472,"symbol":"Slic3r::GUI::NotificationManager::push_hint_notification(bool)","symbolLocation":268,"imageIndex":0},{"imageOffset":8909388,"symbol":"Slic3r::GUI::GUI_App::post_init()","symbolLocation":1332,"imageIndex":0},{"imageOffset":9015532,"symbol":"wxEventFunctorFunctor<wxEventTypeTag<wxIdleEvent>, Slic3r::GUI::GUI_App::on_init_inner()::$_4>::operator()(wxEvtHandler*, wxEvent&)","symbolLocation":64,"imageIndex":0},{"imageOffset":37949356,"symbol":"wxEvtHandler::SearchDynamicEventTable(wxEvent&)","symbolLocation":252,"imageIndex":0},{"imageOffset":37948580,"symbol":"wxEvtHandler::ProcessEventLocally(wxEvent&)","symbolLocation":92,"imageIndex":0},{"imageOffset":37948160,"symbol":"wxEvtHandler::ProcessEvent(wxEvent&)","symbolLocation":56,"imageIndex":0},{"imageOffset":37323604,"symbol":"wxAppConsoleBase::ProcessIdle()","symbolLocation":92,"imageIndex":0},{"imageOffset":35511804,"symbol":"wxAppBase::ProcessIdle()","symbolLocation":24,"imageIndex":0},{"imageOffset":36884044,"symbol":"wxApp::ProcessIdle()","symbolLocation":36,"imageIndex":0},{"imageOffset":37982964,"symbol":"wxCFEventLoop::OSXCommonModeObserverCallBack(__CFRunLoopObserver*, int, void*)","symbolLocation":124,"imageIndex":0},{"imageOffset":527844,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__","symbolLocation":36,"imageIndex":1},{"imageOffset":527568,"symbol":"__CFRunLoopDoObservers","symbolLocation":532,"imageIndex":1},{"imageOffset":525328,"symbol":"__CFRunLoopRun","symbolLocation":1048,"imageIndex":1},{"imageOffset":522404,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":1},{"imageOffset":205756,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":2},{"imageOffset":205312,"symbol":"ReceiveNextEventCommon","symbolLocation":672,"imageIndex":2},{"imageOffset":204616,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":72,"imageIndex":2},{"imageOffset":235056,"symbol":"_DPSNextEvent","symbolLocation":632,"imageIndex":3},{"imageOffset":231360,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":728,"imageIndex":3},{"imageOffset":183280,"symbol":"-[NSApplication run]","symbolLocation":464,"imageIndex":3},{"imageOffset":37107840,"symbol":"wxGUIEventLoop::OSXDoRun()","symbolLocation":160,"imageIndex":0},{"imageOffset":37984696,"symbol":"wxCFEventLoop::DoRun()","symbolLocation":40,"imageIndex":0},{"imageOffset":37471556,"symbol":"wxEventLoopBase::Run()","symbolLocation":112,"imageIndex":0},{"imageOffset":37323084,"symbol":"wxAppConsoleBase::MainLoop()","symbolLocation":120,"imageIndex":0},{"imageOffset":36884136,"symbol":"wxApp::OnRun()","symbolLocation":36,"imageIndex":0},{"imageOffset":37653036,"symbol":"wxEntry(int&, wchar_t**)","symbolLocation":148,"imageIndex":0},{"imageOffset":8866908,"symbol":"Slic3r::GUI::GUI_Run(Slic3r::GUI::GUI_InitParams&)","symbolLocation":292,"imageIndex":0},{"imageOffset":47564,"symbol":"Slic3r::CLI::run(int, char**)","symbolLocation":16348,"imageIndex":0},{"imageOffset":65892,"symbol":"main","symbolLocation":204,"imageIndex":0},{"imageOffset":24144,"symbol":"start","symbolLocation":2544,"imageIndex":4}]},{"id":12296115,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296117,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296119,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296122,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296141,"name":"com.apple.NSEventThread","frames":[{"imageOffset":3568,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":6},{"imageOffset":75992,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":6},{"imageOffset":38456,"symbol":"mach_msg_overwrite","symbolLocation":540,"imageIndex":6},{"imageOffset":4460,"symbol":"mach_msg","symbolLocation":24,"imageIndex":6},{"imageOffset":531420,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":1},{"imageOffset":525512,"symbol":"__CFRunLoopRun","symbolLocation":1232,"imageIndex":1},{"imageOffset":522404,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":1},{"imageOffset":1454664,"symbol":"_NSEventThread","symbolLocation":172,"imageIndex":3},{"imageOffset":28780,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":5},{"imageOffset":7724,"symbol":"thread_start","symbolLocation":8,"imageIndex":5}]},{"id":12296188,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296189,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296190,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296191,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296192,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":12296193,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4376969216,
    "CFBundleShortVersionString" : "PrusaSlicer PrusaSlicer-2.5.0+MacOS-x64-202209060719",
    "CFBundleIdentifier" : "com.prusa3d.slic3r\/",
    "size" : 46546944,
    "uuid" : "fce5a1f3-abc2-350d-9665-5a31c4451f80",
    "path" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/MacOS\/PrusaSlicer",
    "name" : "PrusaSlicer",
    "CFBundleVersion" : "PrusaSlicer-2.5.0+MacOS-x64-202209060719"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6592086016,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5079040,
    "uuid" : "f4ff83fc-e62c-30b4-b3a9-876c8a1fd595",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1953.1"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6750162944,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3358720,
    "uuid" : "02b9797f-c47d-30b7-b7b0-802d0d26f31c",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6645166080,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15761408,
    "uuid" : "af9f6891-70ad-3c26-af08-b747344892d2",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2299"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6588358656,
    "size" : 566464,
    "uuid" : "de46dd52-4994-3fd8-b4b4-e352a1a19354",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6591672320,
    "size" : 53244,
    "uuid" : "886caca0-5762-3640-8db2-3fa3b911c062",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6591438848,
    "size" : 233468,
    "uuid" : "6d6644d3-3db3-34c4-b1e3-c675ec5360f0",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
  "sharedCache" : {
  "base" : 6587711488,
  "size" : 3403612160,
  "uuid" : "2d053604-1cb6-3821-a8df-360eb2eb519b"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)\nWritable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               640K        5 \nActivity Tracing                   256K        1 \nCG backing stores                 4032K        4 \nCG image                          7424K       44 \nCG raster data                      80K        1 \nColorSync                          608K       27 \nCoreAnimation                    178.6M       98 \nCoreGraphics                        16K        1 \nCoreGraphics (reserved)             16K        1         reserved VM address space (unallocated)\nCoreImage                           80K        5 \nCoreUI image data                 3472K       27 \nFoundation                          16K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                           309.8M       55 \nMALLOC guard page                  192K        9 \nMALLOC_MEDIUM (reserved)         960.0M        8         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nSTACK GUARD                       56.2M       12 \nStack                             13.8M       12 \nVM_ALLOCATE                        816K       27 \n__AUTH                             862K      211 \n__AUTH_CONST                      16.3M      396 \n__CTF                               756        1 \n__DATA                            6920K      383 \n__DATA_CONST                      18.8M      398 \n__DATA_DIRTY                       978K      131 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__LINKEDIT                       783.9M        5 \n__OBJC_CONST                      1833K      176 \n__OBJC_RO                         65.1M        1 \n__OBJC_RW                         1981K        1 \n__TEXT                           412.5M      419 \ndyld private memory                304K        3 \nmapped file                      186.1M       26 \nshared memory                     1424K       17 \n===========                     =======  ======= \nTOTAL                              3.3G     2513 \nTOTAL, minus reserved VM space     2.0G     2513 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "name" : "slic3r_main",
    "queue" : "com.apple.main-thread"
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "60da5e84ab0ca017dace9abf",
      "factorPackIds" : {
      "deploymentId" : 240000008
      "rolloutId" : "6112d17137f5d11121dcd4e2",
      "factorPackIds" : {
      "deploymentId" : 240000155
  "experiments" : [
Model: MacBookPro18,1, BootROM 8419.41.10, proc 10:8:2 processors, 32 GB, SMC
Graphics: Apple M1 Pro, Apple M1 Pro, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: Sep  3 2022 02:35:52 version 20.10.965.9.8.7.129 FWID 01-b0e84a9b
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: Laptop, Apple Inc.
Respondido : 22/01/2023 2:35 pm
This is a user to user forum.  You *might* get help if a user has had a similar issue.  If you want to report an issue then you need to open one over on the Prusa Slicer github https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
there are over 2400 open issues and many more closed ones so please do a search with as many likely keywords of both open and closed issues before opening a new one.  A search may also turn up something relevant to help you without opening a new issue too.
Respondido : 22/01/2023 6:18 pm
rwillett
(@rwillett)
I have a Mac Mini M1 and am running 2.5.0 with no problems.
I can see you have the line
I wonder if you have downloaded the X64 version which should just work via Rosetta but for some reason it doesn't. I can't remember how mine upgrades, but it works well under m1 chips.
Mine says ARM64 rather than X64.
Rob
Respondido : 31/01/2023 8:57 pm
iftibashir
(@iftibashir)
Running 2.5.0 on a MacBook M1 Max - no issues.....
Looks like its something local to your machine rather then the slicer.....
Respondido : 02/02/2023 9:39 am
