Prusaslicer won't set my bed temp higher than 60C
lunarLarceny
(@lunarlarceny)
Mitglied
Hello, I've been having a problem where I set the temperature of my bed to 70C, but the gcode Prusaslicer produces makes my machine run the bed temp at 60C, forcing me to change the temperature manually every time I print. I have tried another slicer and it has no problem setting the bed temperature to 70C, so what exactly is the problem with Prusaslicer? If anyone knows how to fix this issue or at least troubleshoot, please let me know.
Thanks, everyone!
Veröffentlicht : 11/10/2023 7:43 pm
RE: Prusaslicer won't set my bed temp higher than 60C
If you can post your zipped up 3mf project file, we can check your settings to see what's causing it.
Veröffentlicht : 12/10/2023 11:33 am
lunarLarceny
(@lunarlarceny)
Mitglied
Prusaslicer pkg
Here you go, I zipped up the 3mf and the gcode. Please tell me if you need anything else!
Veröffentlicht : 12/10/2023 7:20 pm
The problem is your printers profile start gcode.  You need to be in Expert mode to see all the settings.  Then you need to go to your Printer Profile>Custom Gcode section.
you have the following at the start
M140 S{first_layer_bed_temperature[0]} ; set final bed temp
M105 ; get temperature report
M190 S60 ; wait for bed temperature - 60 seconds
M104 S{first_layer_temperature[0]} ; set final nozzle temperature
M109 S{first_layer_temperature[0]} ; wait for hotend temperature
M82 ;absolute extrusion mode
; Ender 3 Custom Start G-code
G92 E0 ; Reset Extruder
G28 ; Home all axes
The M140 gets set to 70 as that is your filament profiles first layer bed temperature.  However just after that your start gcode is manually setting it to 60 with the M190 S60.  Basically making the previous M140 pointless.  Its basically saying heat to 70 then heat to 60 and carry on when it hits 60.  That M190 S60 does NOT make it wait for 60 seconds.
M190 is set the temperature to Sxx and WAIT for it to reach that temperature.
It does not get set to 70 later as the first layer temp and other layers temp in the filament profile are the same.  When they are the same it doesnt insert any other temp commands for the bed.  If your filament profile had 71 set for the other layers then it WOULD change the bed temperature after the first layer but that first layer is hardcoded to 60 degrees by your start gcode.
You need to sort out the ordering/commands
Other problems in there, is you haver the extruder set to relative extrusion which is good, you even have the required
;BEFORE_LAYER_CHANGE
G92 E0
;{layer_z}
Needed for relative extrusion, the problem is you have your start gcode set to ABSOLUTE extrusion with the M82.  Thats not compatible.  You would be better off replacing the M82 with M83 ; extruder relative mode
Basically the print profile you are using is wrong.  Not sure where you got it from.
For the temperature setup a better block would be -
M104 S[first_layer_temperature] ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] ; wait for extruder temp
Veröffentlicht : 12/10/2023 9:10 pm
lunarLarceny
(@lunarlarceny)
Mitglied
Okay, I changed the start code, here's how it reads now:
M83 ; relative extrusion mode
G28 ; Home all axes
M420 S1 ;enable mesh editing
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
Is this good now?
Veröffentlicht : 12/10/2023 9:27 pm
